Configures a VLAN traffic group, which links all the ingress ports in the specified VLAN to the specified egress QoS profile.
| vlan_name | Specifies a VLAN name. |
| vlan_list | Specifies a VLAN list of IDs. |
| qosprofile | Specifies an egress QoS profile. The supported values are: qp1 to qp8 and none. |
None.
Extreme switches support eight egress QoS profiles (QP1 to QP8) for each port. The QoS profile QP7 is not available to you on a SummitStack.
configure vlan accounting qosprofile qp3
This command was first available in ExtremeXOS 11.0.
The vlan_list option was added in ExtremeXOS 16.1.
